jpederson
Sep 08, 2020Aspirant
RBK50 dropping WiFi
I bought the RBK50 setup at the end of April of this year. It's worked great until the last 2 or three weeks. Now my WiFi connection is dropping constantly. I reset the entire setup and it works for a few minutes at best, and it's gone again. Of course I'm out of warranty and this is my only option for support. I tried updating firmware, but my version says it's current.
For the money I spent, I expect a better product. Now I have 2 expensive paper weights........
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- jpedersonAspirantMy firmware is 2.5.1.16
My modem is a Horton PC20
Our house is 3500 sq ft. My router is on the second floor with a hard line to the satellite on the first floor.
I have the Ethernet from the modem to the Orbi router, then from the orbi router into a to link tl-sg108 gigabit switch. From there to the orbi satellite on the main floor.
I have the 2.5 on auto and the 5 on channel 40. The 5 was on 44 but I changed it to see if it would work. I don’t see an auto option for the 5
I have one neighbor with a WiFi signal that’s been here longer than my Orbi- jpedersonAspirantDamn auto correct. The modem is a hitron not Horton
