vreynolds
Jun 06, 2017Luminary
RBK50 is a downgrade from my Nighthawk R7000 for me
Firstly, I've glanced through some of the threads here and didn't find an exact match for my issue. I am replacing my Nighthawk R7000 due to some deadspots around the 2-level house. My wifi door...
- Jun 06, 2017
Fixed!
As I suspected, there is no way this system should be slower than the R7000 - it was user error. I had an errant Wifi extended tucked away under the couch to keep it away from the kids. I had forgot about that. Once I unplugged it, then I didn't even need to reset the router or sattelite. It's all working well now. I tested in random places with a wifi analyzer, and the signal is strong everythere. It isn't as strong at my front doorbell, but only one way to find out. I'll switch wifi networks and test.
Now I can get rid of my extenders and powerline bits and pieces.
vreynolds
Hi - In the limited testing I did yesterday, the signal was poor to the locations which the Netgear R7000 was reaching. Example is my Ring Doorbell - I got better signal with my R7000. Also, my master bedroom Echo dot, I constantly got 4 bars wifi, but with Orbi, I get anywhere from 2 to 3, and of course connection dropping.
I could not spend hours troubleshooting because I have to go on with my life, but will try again when the family is out of the house. We rely on wifi too much nowadays.
I'll take your advice and read through some of the threads, but this seems highly suspect to me. The Orbi 2 pack should offer much better signal than a single old R7000 router. I am dissapointed and frustrated that I have to possibly spend hours troubleshooting a brand new router.
gfrey
Jun 06, 2017Apprentice
Yep you are doing something wrong. I have a 2 story house with a ton of WiFi IoTs attached (Nest Cams, Nest Thermos, Android TVs, ChromeCasts, Echo, Google Home, etc) all around the house. I recently added a 3rd Satellite so that my backyard had coverage. I get 200Mbps-300 Mbps throughout my house with zero dead spots. Even in my backyard, I will get 100Mbps easily no matter where I am standing. The only issue I have had is with the Implicit Beam Forming as I had to shut it off or I would get disconnects. I also had a Nighthawk prior to the Orbi and I had way too many dead spots using it. Positioning of the Orbi Satellite is key...
