vreynolds
Jun 06, 2017Luminary
RBK50 is a downgrade from my Nighthawk R7000 for me
Firstly, I've glanced through some of the threads here and didn't find an exact match for my issue. I am replacing my Nighthawk R7000 due to some deadspots around the 2-level house. My wifi door...
- Jun 06, 2017
Fixed!
As I suspected, there is no way this system should be slower than the R7000 - it was user error. I had an errant Wifi extended tucked away under the couch to keep it away from the kids. I had forgot about that. Once I unplugged it, then I didn't even need to reset the router or sattelite. It's all working well now. I tested in random places with a wifi analyzer, and the signal is strong everythere. It isn't as strong at my front doorbell, but only one way to find out. I'll switch wifi networks and test.
Now I can get rid of my extenders and powerline bits and pieces.
vreynolds
Yep I figured I am doing something wrong. That's the only way to get these low speeds and disconnects. But, what am I doing wrong is the main question. I've followed the procedure according to the instructions, but only once. I will reset and start over again. Someone suggested to set up just the router first, then set up the satellite after everything is done. This is what I will try this afternoon. Yes I am also hoping for no dead spots. I will update the thread after trying it this afternoon.
- vreynoldsJun 06, 2017Luminary
Fixed!
