ratjunior
Oct 30, 2020Aspirant
RBK50 Satellite
Hi All,
I have a RBK50 set. I want to add a satellite to extend my reach. I know that I can use a RBW30 or a RBS40V as satellites. I was wondering if I can use any other satellites that plug directly into the wall that may be a little more affordable. I dont want to lose any of the features the orbis offer. Something like an AC50 is what I was looking at.
Thanks
Yes, the RBW and RBS series are all satellies. The only ones that won't work is the 1 series.
Also the RBS50Y outdoor series works too. Also EX7500, 7700 and 8000 extenders also work too. Though these don't support the backhaul feature.
- ratjuniorAspirant
Thanks FURRYe38,
I think I will be going with the RBW30. I think it will best work for us. Dont need another Alexa something, nor the one made for outside that you mentioned.
BTW: What is the "backhaul" you mentioned? Is it critical for operation? I am not a network engineer!
Thanks!
For Orbi units yes.
