bottle
Aug 02, 2017Follower
RBK50 separeted Lan ports and wifi.
Hello.
We are using Orbi AC3000 Tri-Band WiFI system (RBK50), firmware 1.12.0.18. Laptops are mainly PCs with xp,7 or 10. In those we use browsers such as Mozzilla firefox or Google Chrome, if this is relevant infoarmation.
I have connect sound devices to Lan port 1 with cable. Light and video devices to Lan port 2 with cable. I am trying to separate those Lan ports from each other so that the devices in Lan port 1 cannot "see" devices in Lan port 2 and vice versa. Wifi should also be the same that i would have "sound" and "light/video" wifi. And if you join one of those you should also be able to access internet.
Our reseller told me that this should be possible. i added a picture to give the idea what i am trying to do.
greats. bottle
1 Reply
- st_shawMaster
Orbi cannot provide this kind separation. For that, you would need a more sophisticated router with support for multiple LAN subnets and multiple segregated SSIDs.
