RickJo's avatar
RickJo
RBK50 Unable to use Orbi Traffic Meter feature to round up data by coonnection
How does one get to and use the check box and Traffic Meter feature described as "Round up data volume for each connection by"?  It seems in accessible and unusable to me.
  • FURRYe38's avatar
    This feature maybe something that hasn't been fully enabled by NG in the FW.
    What version of FW are you using currently?
    • RickJo's avatar
      RickJo
      My firmware:
       Model NameDevice NameCurrent VersionStatus
      RouterRBR50RBR50V2.1.2.18No new firmware version available.
      • FURRYe38's avatar
        This is sometihng I don't see with my router. I'm on a beta just up from v.18. Not sure if this is a feature that has been removed or will be or only seen on certain modem Orbi systems.
        You might contact NG support and ask about this...
