ElCapo
Mar 24, 2018Luminary
RBK53 - Clarification on Ethernet Backhaul Set-Up
Hi i am hoping someone can help me clear up some questions regarding the setting up of my RBK53 Orbi router and two sateliites in an Ethernet Backhaul configuration. I have looked at the link below...
- Apr 06, 2018
OK..
Just touching base after a couple of weeks of testing.
As soon as I changed to Firmware 2.1.3.4 I was able to set up the Ethernet Backhaul. A quick check with IPERF3 showed good speeds across the network both wireless and wired. So far since last update everything has been stable.
Couple of points:
- My Orbi Router (in AP Mode) is connected to my Broadband Router via Ethernet into the Yellow WAN port
- My 2 x Orbi Satellites are connected to the Broadband Router via daisy chained un-managed switches
- After setting up the two satellites wirelessly first, then moving one by one to Ethernet I did see their IP addresses on the Router Conntection Page flick between 192.168.1.x (x being the actual address) and 192.168.1.250. Once I restarted each device this ceased to happen and they settled on the 192.168.1.x address.
Thanks to all support on this post.
Mar 26, 2018Guru - Experienced User
What is the Mfr and model# of the ISP Modem?
If this has a router here and has not been disabled and set up for bridge mode, you can either use the DMZ option here for the IP address the Orbi router gets from the modem and use the Orbi router in router mode, or don't use the DMZ on the modem and use the modem as your main host router and use the Orbi router in AP mode. AP you can use either the wan or LAN port to connect the orbi router to the modem. If you have the orbi router in router mode, you have to use the WAN port to connect to the ISP modem.
- ElCapoMar 26, 2018Luminary
Hi
my modem / router is Huawei 963168_HUAWEIVOX25
It does have the option to set up the remote host / dmz, which I am a little nervous to do, especially having had a little read up on it. But I take your point that in AP mode it does not matter what port I use on the orbi router.
- FURRYe38Mar 27, 2018Guru - Experienced User
DMZ would be only if you wanted to try the Orbi system in router mode. Don't use it for AP mode.
Let us know how it all works out for you. You have your suggestions.
