the5rivers's avatar
Mar 06, 2020
RBK53 AP Mode Not Working with TDS Fiber Modem
Hello everyone. I have searched through the forum and on the web and cannot find info specific to my situation. I have fiber through TDS, they have provided a Calix 716ge modem (ONT), and my RBK53 router is connected to the LAN 1 port of the modem via the WAN port.
I am interested in running a wired backhaul and understand that the router must be in AP mode, however when I switch from router to AP mode, the router will reboot and then ultimately settle on an LED color of solid magenta, indicating it could not get an IP address. I have rebooted the router, rebooted the modem, disabled DHCP in the router prior to swtiching to AP mode, inserted the ethernet wire from the modem into the LAN 1 of the router, but nothing has eliminated the error.
I believe this error has to do with my modem, and probably need to put it in bridge mode, but wanted to see if anyone could offer any other insights. I searched for login info on the web for the calix modem and could not find anything relevant.
Thank you very much for your help.
  • FURRYe38's avatar
    If your ONT has a built in router already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure to power OFF the ONT for 30 seconds then back ON. Reset the RBR and walk thru the RBRs setup wizard with a wired PC and web browser.
    • the5rivers's avatar
      the5rivers
      Tutor
      Hi thanks for the reply. I have seen you post this "double NAT" reply in other related threads as well, but I don't think it applies to my situation unfortunately. I am currently running the most recent FW 2.5.1.8 on router and two sats.
      TDS is telling me that the ONT does not have modem capabilities and no interface that I can log into. It is also NOT a router. They mentioned that the modem they use is an actiontec T3200, but I was not given one because I have a fiber connection and there was no need. As far as I can tell, I have no way to access the ONT settings.
      Do I need to buy a cheap modem and put that between the ONT and the RBR50 in order for this to work?
      • FURRYe38's avatar
        You need to ask your ISP what is needed so that you can interface the Orbi's RBR to there services. There needs to be some form of Ethernet interface connection at the ONT or some router or modem that the RBR can connect to for its' WAN port connection.
        The Actiontec is a gateway modem, which can be used however already has a built in router and wifi.
        https://www.windstream.com/support/internet/wi-fi-network/Actiontec-T3200
  • Regardless of if the Orbi is in Access Point or Router mode, the cable from your ISP modem needs to be connected to the Internet port of your Orbi router - no?
      the5rivers
      Tutor
      It is connected to my wan port, and is currently working correctly via a wireless backhaul. I was just listing different countermeasures that I deployed to see if anything would resolve my issues when switching it to AP mode.
