Hinkvdp
Aug 01, 2021Tutor
RBK53 flashing white light
Dear,
i've a orbi RBK53 and since a last reboot, the router is continously flashing white with no internet as a result. I can't connect anymore via ip-address or via website to the router. It appears that the system is death.
I've read how to install manually the firmware update via eternet cable but that didn't help neither.
We've both the orbi in May 2019, so pretty young to have a faitall system error.
Any suggestions ?
Thanks,
Hink
Hi,
the problem is solved..
It was a corrupted installation of the new firmware which messed up the whole system.
After a new download (from the netgear-website) and a reinstallation on both Router and the 2 satelittes, the issue was solved.
Thanks for the support,
Kind regards,
Hink
> cable but that didn't help neither.Thanks for the helpful link(s). With my weak psychic powers, I can't
guess what you read, or what you did, or what happened when you did it.> [...] the router is continously flashing white [...]
The whole _router_ is?
If what you have corresponds to a flashing power indicator on a
non-Orbi router, then you might be a candidate for the TFTP recovery
scheme. See, for example:- FURRYe38Guru - Experienced User
Any updates on this?
Hinkvdp wrote:
Dear,
Any suggestions ?
Thanks,
Hink
- HinkvdpTutor
Hi,
Kind regards,
Hink
Glad you got it working.
Enjoy.
