esko1954
Aug 08, 2017Tutor
RBK53 networkwing with Cox Arris tg1682g
Cox just replaced their cable modem with Arris tg1682g. I would like to have one seamless network. Currently, if i connect a device to the router than it can't speak to any devices on the Orbi. Is it possible to bridge the two togehter for seamless wired and wireless environment.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello esko1954
You would have to look in the settings of your modem to find a modem only option this should allow you to use orbi as your main router.
DarrenM
