samiam1234's avatar
samiam1234
RBK53S no internet connection
Hello,
I recently bought an Orbi RBK53 to use with my Cox (ugh) internet at home. I turned the panoramic modem/router into bridge mode (Technicolor CGM4140COM) using the login page at 192.168.0.1. After this I unplug the device and plug it back in, connect the orbi and satellites as instructed using the app. The App on my galaxy S10+ is able to connect to the orbi, but unable to detect an internet connection. If I plug my laptop into the modem I get internet, but not if I plug it into one of the ports on the Orbi.
Has anyone had similar issues or any suggestions for me to try?
Thanks!
  • What Firmware is currently loaded?
    Factory reset the RBR and use a wired PC or laptop connected to the RBR and walk thru the setup wizard with a web browser. I would also power OFF the isp modem for 30 seconds while the RBR is reset. Then log into Orbilogin.com or 192.168.1.1 with a web browser and begin the setup wizard.
  • FURRYe38's avatar
