wrleeii's avatar
wrleeii
RBK53s Router drops modem connection
After 6 mo,the RBR50 router (part of the RBK53s package) has suddenly started dropping its connection several times a day. I either have to push its Sync button or when that doesn't work, power cycle it to get a connection again. Many times it will drop and it will resync itself after a few minutes without my pushing the sync button. I have not updated the firmware recently (v2.3.5.30), so I do not know what has triggered this behavior. The modem it's connected to is fine; I have not needed to power cycle it.
Frustrating! Should I look at replacing it?
  • CrimpOn's avatar
    CrimpOn
    Fortunately, Netgear provides a one year hardware warranty with Orbi.  So, if actually has "gone bad", they should replace it.  The task is to demonstrate that it has in fact malfunctioned (not easy, since it actually does work for hours at a time).
    This is the first I have heard of using the "Sync" button to restore a modem connection.  As far as I know, the Sync button has only one purpose: to connect a device TO the Orbi (either an Orbi satellite or some user device).  In that case, a sync button has to be pressed on both devices to link them.  Given that the sync button appears to restore the modem connection for you, I am mystified.
    As the Orbi does not typically have to be powered off, my first step would be to look at the Orbi log file for the period when the modem connection went down.  That is on the Orbi web interface, Advanced Tab, Administration, Logs.
    Does the "ring light" at the top of the Orbi indicate anything when the modem connection goes down?
    Here is what the Orbi lights are supposed to do: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    • wrleeii's avatar
      wrleeii
      Thank you for your comments. I thought the sync button's behavior odd, as well; though it only works sometimes. I hadn't changed any of its configuration in several weeks. Suddenly, a couple of weeks ago, it started dropping. When I go to it, the ring light is either off or pulsing white. If pulsing, then usually it will reconnect by itself after a 2-3 minutes. If off, I try holding the sync button for a few seconds to see whether the pulsing starts (an indication that it will reconnect). Often, nothing happens, so I have to power-cycle the router. After turning the power back on and waiting a few seconds, the white ring light will blink for several seconds before it changes to its pulsing. The pulsing, I take as a sign that a reconnection is in progress—which it does.
      Once, I approached to find the ring light blinking rather than pulsing—i had to power-cycle it.
      I tried looking at the logs, but no obvious errors were showing (I'll have to look again, more closely)
      Through the Netgear support pages, I could not contact them. I also tried selecting the link to replace it and I was directed to an invalid page.
      • FURRYe38's avatar
        Try some of the suggestions as well.
  • FURRYe38's avatar
    The most current FW version is v2.5.1.8. Stable and working for me.
    Is the Orbi system operating in Router or AP mode?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
