Notdonor's avatar
Notdonor
RBR 20 obtaining IP address errors
Hello, recently my network has had some frustrating issues connecting various things to my router. I can connect all smart phones and tablets fine. I can not connect my desktop with a wireless adapter in it or my ps4 pro wirelessly to the system. My regular ps4 connects fine. I am getting failed to obtain IP address errors on the things I can't get to connect. Please help!
  • FURRYe38's avatar
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Notdonor's avatar
      Notdonor
      Current Firmware is V2.5.1.16
      Modem is Arris TM1602
      Distance between satellites is 20-30 feet
      I have made all the changes you suggested and its still the same.
      Router was factory reset and resetup this afternoon.
      • FURRYe38's avatar
        What is the mfr and model # of the wifi adapter on the PC?
        Be sure the adapters wifi driver is updated.
        I have heard of some PS4s not connecting wirelessly to Orbi. If the other PS connects and the other doesn't, I would presume there maybe a difference on the Pro version. Something to ask Sony about. I would wire connect the Pro version to see if it connects to the back of the RBR.
