ipp's avatar
ipp
Follower
Mar 15, 2021
RBR dropping wifi connection
I have been using RBR50 for the past 3 years. Had no issues until last week. Wifi connection keps dropig off. Hae to reset the ruouterand it woks for a whil and requires resetting. I have reset the router at least 10 times in last 2 days. Router Firmware Version V2.7.2.104. 2.4MHX is set Ch #6 and 5GHZ is set to 48. Please help.
  • Same here. Happened just from today. Working fine for the past three years and the time I had to restart the router in today is larger than all counted.
    The only thing that came to my mind is I've updated to 2.7.2.104 recently, nothing else changed. With that said, I think I've updated for around a week or two with no issue, but just happend today(Mar 15, 2021).
    I'm considering to downgrade to the orginal firmware, but I cannot remember that number.
  • FURRYe38's avatar
    Any RBS deployed? What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try setting Auto on 2.4Ghz. 40 on 5Ghz.
    Armor, Circle, Daisy Chain, Fast Roaming, Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
      • Ha_Ku_Na's avatar
        Ha_Ku_Na
        Luminary
        I'm on 2.7.2.104 and using a pi-hole as DNS server (configured in Orbi "Use These DNS Servers" -> only pi-hole IP configured in "Primary DNS"). Never saw this issue.
        If someone has issues with his Orbi system I suggest this procedure:
        1) take a backup of the config on Orbi
        2) Reset to factory default
        3) setup Orbi and reload the saved config from step 1
        If this does not help, then we can think about a firmware downgrade or reapply of the same firmware file again.
  • I've downgraded to the previous firmware and so far I did not experiense any disconnection.
    As just a user, I really do not want to know how to set some complex parameters in advanced settings, I just need it work as expected. So from my point of view, latest firmware has defect but the previous not. Shouldn't the responsibility of Netgear to analysis into the latest fw to fix this? Why ppl are here being mean to each other?
    • vajim's avatar
      vajim
      Master
      Hi Frankca2015
      We're glad things are for the better.
      No one in here is being mean.  Sometimes we disagree, but at the end of the day, we're all learning and sharing.  Thanks for your post.
