tim-c's avatar
tim-c
RBR20 and a satellite, won't connect to amazon or any other internet other than Netflix.
I'm just having issues connecting to Amazon and everything else. Everything has been set up and Netflix works but nothing else.
Any thoughts or help would be appreciated.
Tim
  • CrimpOn's avatar
    CrimpOn
    What device is attached to the Orbi network and cannot reach anything besides Netflix?
  • plemans's avatar
    Firmware on your orbi?
    What modem/gateway is it connected to? (model)
    • tim-c's avatar
      tim-c
      Evening,
      Thanks for the reply, the firmware on the Orbi is v2.3.5.30.
      The router I'm running off of is an Action tech M1424.
      Thank you,
      Tim
  • FURRYe38's avatar
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
