Anzy
Jan 06, 2020Aspirant
RBR20 Doesn't factory reset and lost wifi capabilities
Hello,
Since we moved all our satelites and the router around my house I went ahead and tried to setup a new system. It had problems finding the newly named wifi and couldn't proceed with the setup because i had no connection to it on my phone. I went ahead disconnected all my satelites and factory reset the router with holding a pin into reset button until it was blinking amber. After i let the button off all the lights shut off and left it out for about 15 minutes and nothing happened. I went ahead and turned of the router as it was apparently stuck, the amber light blinked and the router turned off. After i turned it back on, the green light was back behind and the orbi was blinking white, after a while turning into a solid white, it never dissapears. I've also tried doing the 30-30-30 reset but no luck. I can't even get to the router menu with cable as it prompts me to orbi app instead, which i can't use as wifi isn't detectable for some reason. Hope somebody has any alternative solution to this.
Anzy wrote:I can't even get to the router menu with cable as it prompts me to orbi app instead, which i can't use as wifi isn't detectable for some reason.
Please describe what happens when the RBR20 is not connected to the modem, you attach a computer to the RBR20 LAN port, power the Orbi on, and use the paperclip until the power LED turns amber and blinks. A web browser should connect to the Orbi at http://192.168.1.1
and this doesn't happen?
- AnzyAspirant
As i have mentioned before what happens it it prompts me to the mobile app and doesn't let me in the router settings through wired connection.
That is where I am confused. Something comes up on the web browser from http://192.168.1.1 instead of the Orbi home page?
