robert1308's avatar
robert1308
RBR20 dropping internet connection regularly
Since a couple days, as far as I remember after the upgrade of firmware, the internet connection drops regularly while the WIFI is still connected. I checked the WAN connection status, it is disconnected. Anything I can do?
    There have been several posts about updating firmware and having issues.
    What firmware is installed your Orbi RBR20 have on it? The official release is 2.5.1.16
    • robert1308's avatar
      robert1308
      I have the latest firmware version 2.5.1.16
      I've gone through several similar posts, none of them provides a reliable solution
      • FURRYe38's avatar
        Do you have Armor or Circle enabled?
