oceanaveprops
Dec 27, 2023Aspirant
RBR20 guest network password keeps dropping
See a bunch of others with a similar issue but other models. The guest network password keeps dropping from the settings when entered and applied. The guest network then has an open network even though the password and security type was set. Firmware is up to date (latest) based on the firmware update check and netgear site for most current FW (v2.7.4.24). anyone know what the fix is for this? seems like should be pretty straighforward given every other aspect of the system settings are working fine.
- KevinLiTNETGEAR Moderator
Hello oceanaveprops ,
Welcome to the NETGEAR Community!
I understand that you are not able to set the password to your guest network successfully. Please try navigating to orbilogin.com and then disable the guest network. Then enable your guest network set the password then restart your system.
Best,
Kevin
Community Team
- oceanavepropsAspirant
Thank you. went to that url and logged into site. however, not sure where to go from there in order to see my ORBI settings and make the updates you recommended.
Please provide further details or if I'm in the wrong area or site.
Thank you.
Guest network is described on page 80 of the RBR20 user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
