drussi's avatar
drussi
RBR20 keeps dropping internet connect and flashing magenta
For the last couple weeks my RBR20 keeps dropping the internet connection and flashing magenta. If I reboot the Orbi connected to my ISP then the internet comes back for a while. I've verified if I just plug wired connections directly with the ISP then those work.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    If you see pink on the top ring LED, means the RBR has lost the connection to the ISP modem or the ISP modem is not longer getting data to the RBR. https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Something to check with the ISP with to ensure there modem/ONT is working and if they notice anything during these time frames when this happens.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
