Jenn1949's avatar
Jenn1949
RBR20 no sync satellite
My RBR20 router will not sync with RBX33 plug in satellite
Tech support for over and hour
Please advise on if compatibility issue or bad satellite
Thank you for your help
  • FURRYe38's avatar
    What FW version do you have on the RBR and the RBW? If you can access the RBWs web page. Possible that the RBWs FW is out of date or out of sync and needs to be updated? Did NG discuss this with you?
    • Jenn1949's avatar
      Jenn1949
      Thank you but you are dealing with a MeMe
      What is FW?
      And how do I go to a website?
      Thank you
      Also received offer to purchase Pro warranty but every time I click on it, I go to Netgear with no info on purchasing the warranty.
      Do I need to call. Netgear as I only have one more day to accept this offer
      Thank w
      • FURRYe38's avatar
        FW=Firmware
        Log into the RBRs web page with a PC or laptop wire or wireless connected to the RBR. Navigate to orbilogin.com or 192.168.1.1
        Yes you'll need to contact NG support for warranty help.
        Blanca_O
