nmklong's avatar
nmklong
Tutor
Jun 24, 2020
RBR20 satellite acting up after firmware upgrade to 2.5.1.16
So i saw a new firmware update and decided to update to 2.5.1.16 a few days ago. After the update, i notice i have troubles with the wifi pretty often.
I tested internet speed directly from the router and it was still super fast. So i had doubts on the satellite and tested by turning it off so that everything is connected to the router, everything works fine, turned it back on and monitored the Attached Devices list to see which one is connected to the satellite, and everything that connects to the satellite has problems.
Is this a faulty firmware version? Did anyone run into the same issue? Does anyone know how to solve this? Maybe i will need to roll back the firmware by manual update? Will this be possible to do?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Has a factory reset and setup from scratch been performed since last FW update? Something to try if you haven't already.
    • nmklong's avatar
      nmklong
      Tutor
      I use my own cable modem "NETGEAR Cable Modem CM500" and Orbi is connected via a LAN cable.
      Orbi operating in Router mode
      1100 sqft, they are in good distance, Orbi system was working fine for over a year until the firmware update
      Auto currently, i can try setting it to 1, 6 or 11 but not sure if this will help
      I believe around 7-8
      Both are enabled since when i set up Orbi system
      Try disabling the following and see: Armor, Circle, Daisy Chain, Fast Roaming, IPv6
      All these are already disabled
      Already the current state
      Currently set to Auto, i can try setting to Short
      Has a factory reset
      If all above fail, i may have to do this and update to the firmware before 2.5.1.16
      • FURRYe38's avatar
        I would change to 40Mhz as well.
        Be sure the Orbi system is not using same channels as your neighbors if possible.
        Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
        Give a reset of the system a try too.
    • nmklong's avatar
      nmklong
      Tutor
      FURRYe38 had to go down the factory reset path, but even when pushing the reset button, it blinks amber already but when i log back into admin, set up the wifi network name again and stuff, the firmware is still 2.4.1.16, how to really factory reset? :(
