doctboo's avatar
doctboo
RBR20 won't allow MacOS update
So, I don't know if it was the last firmware update or what, but my ORBI RBR20 gives me the dreaded "The request timed out" message that's been going around if I try to use MacOS Update. I know it's the router because:
  1. My house has a hot Cat6 from the ISP, i.e. no modem, and the updates work just fine if I bypass the ORBI.
  2. I did a factory reset on the ORBI to make sure it wasn't some setting I tinkered with previously.
  3. I've tried all the published workarounds for the time out error and none of them work.
Anyone else run into this?
Any ideas that aren't
  1. Boot into Safe Mode
  2. Update the DNS
  3. Bypass my ORBI and use the hot line coming into the house to run updates
  • FURRYe38's avatar
    Are you getting a private IP address from your ISP? 192 or 172 or 10 IP address on the WAN or Internet side of the RBR? If so, there is a upstream router in front of the RBR. A public IP address from the ISP is preferred, ##.##.###.###.
    What FW version is currently loaded?
  • Retired_Member's avatar
    Retired_Member
    Was your network ever working correctly?  If so, what changed?
