alexsos
Jul 10, 2020Aspirant
RBR40 - frequently lost connection - over payed routers?
Hi,
I've been having the same problem for months now. I'm using radio internet access and then use my Orbis inhouse. RBR40 and 1 satellite. The problem is that frequently I'm losing internet connection for usually up to 5 minutes, sometimes longer. I don't have full wifi coverage so I limited the case to LAN connection and it still exists. Below some records from my recent Network Logger.
Today technician from my Internet provider came and changed my Orbis for the test for simplest (and much cheaper) TP-Link router. Five hours have passed without any outages.
Now, I should be happy but I'm annoyed, especially if it proves that my Orbis were making the whole mess. My satellite is not working but Internet is stable now.
Are there any immanent problems with Orbis, that you are aware of, that can be causing this situation?
Cheers,
Alex
Jul 09 20:07:18 PM
Connection Outage Detected
Jul 09 17:57:14 PM
Network Up. Outage lasted 4 minutes, 55 seconds.
32 tests failed during the outage.
Jul 09 17:52:19 PM
Jul 09 11:52:09 AM
Network Up. Outage lasted 5 minutes, 6 seconds.
34 tests failed during the outage.
Jul 09 11:47:03 AM
Jul 09 11:42:02 AM
Network Up. Outage lasted 4 minutes, 56 seconds.
Jul 09 11:37:06 AM
Jul 09 10:37:11 AM
Network Up. Outage lasted 5 minutes, 9 seconds.
Jul 09 10:32:02 AM
Which network logger are you using?
Is it periodically checking for connection to an external resource?
- alexsosAspirant
CrimpOn wrote:Which network logger are you using?
Its name - Network Logger Pro, on my iMac
I guess not, I guess it's pinging out from my end. It does such test every 30 seconds or so. Logistics provider was checking logs at their side and didn't record any problems. They even built some extra mast on my roof because assumption was that leaves are causing the problem.
alexsos wrote:
CrimpOn wrote:Its name - Network Logger Pro, on my iMac
Thanks. Network Logger Pro: https://networklogger.net/ Item #4 on the FAQ explains that the program makes periodic ICMP (ping) and HTTP requests to report connectivity. https://networklogger.net/support/ (That is how every network logger that I have seen functions.)
Is it correct to assume that you began logging because you noticed interruptions in service?
Is there a distinct pattern to the service interruptions?
In particular, do they correspond to the end of the DHCP lease period that is reported on the Orbi web interface, Advanced Tab, clicking on the "Connection Status" box?
- john442Tutor
Are you running Circle parental controls? This has cause random internet drops...
- john442Tutor
Not sure on Armor, not running it.
I know Circle causes issues... I had tons of drops, valided with Charter that my modem had no disconnects. Disabled Circle..haven't had a disconnect since....before at least 2-3 a day. Spent hours debugging it...
I do have an open support case for it....
