TheFwGuy's avatar
TheFwGuy
Follower
Sep 04, 2025
RBR40 - VPN stopped to work
Hi, I do have an RBR40 with 3 satellites.
Until some time ago (can't quantify, sorry) I had the VPN working nicely.
Now is not working anymore, I can't even enable it clicking on the box and then Apply.
Nothing happens. If I refresh the page after the Apply it shows disabled.
There is something I can do ?
Or I have to trash away the system because obsolete ?
Thanks
  Steve
1 Reply
  • plemans's avatar
    Its not obsolete. The RBR40 is still pretty solid depending on how you're using it.
    VPN should still work.
    Going over your vpn company and settings might help.
    Or even just try a factory reset and re-doing the settings might help.
    What modem/gateway are you using?
    Did anything else change (modem, settings, etc)
