Ultraklassic
Jan 12, 2022Aspirant
RBR40 AND DOCSIS 3.1
I have a new Arris SB33 DOCSIS 3.1 modem connected to an Orbi RBR40 router system with 3 satellites. I suscribe to Vyvebroadband for my cable needs and I have the 1Ghz download package. My Arris modem displays 2 lights to notify the user that the modem is in DOCSIS 3.0 (green light) or DOCSIS 3.1 (blue light) mode. Vyvebroadband is swearing that the modem should be in DOCSIS 3.1 mode according to their settings but my light is GREEN and not BLUE. So my question is: Is the limiting factor from receiving DOCSIS 3.1 my Orbi RBR40 router???? There is, of course, no button on the Arris SB33 modem to manually switch between the two DOCSIS speeds, as its "automatic".
Sort By
- UltraklassicAspirant
..........or is my Cable provider lying to me regarding their ability to deliver DOCSIS 3.1????:smileyfrustrated:
This modem has only one LED, which uses different colors to indicate status. See page 9:
I see two possibilities:
- What Arris describes as 'blue' may appear 'green' to you.
Color tests are widely available on the internet. They are quick and sort of entertaining. I found this one almost fun:
https://www.colorblindnesstest.org/ - There is a problem with your cable drop which affects some of the frequencies and the ISP is unaware of it.
Are you able to log onto the modem? (Page 15 of the manual) and navigate to page 18? That is supposed to indicate the status of the modem.
- UltraklassicAspirantBeen busy at work guys so thanks for the replies. I have not called the ISP yet but I did log into my modem and this is what I see. Do these numbers look acceptable???
My modem is still showing a green light indicative of DOCSIS 3.0 when it should be blue for DOCSIS 3.1. I will check my cabling for crappy splitters to rule that out as a potential communication issue.
And BTW, I passed the Color Blind Test.... LOL🤣🤣🤣🤣🤣
Would be the modem. You'll need to contact the Modems Mfr for additional help and support regarding there modem. Also keep in contact with your ISP. They'll need to check the signal on the lines up to the modem and check cableing.
Good Luck.
What speeds do you get directly connected to the modem?
