Chev3re525's avatar
Aug 11, 2022
RBR40 Limited to 866Mbps
I Have 1GB Service with Frontier, but My Orbi RBR40 Limits Bandwidth To 866
Mbps. Anyone Else Experiencing That?
  • plemans's avatar
    If you look at its spec sheet, that is its specs.
    It has a 866mbps 5ghz backhaul, a 866mbps 5ghz front haul, and a 400mbps 2.4ghz.
    https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
    so its not "limited to" but is what its actual link speed is.
    Even the 50 series only has the 866mbps front haul but it has a wider 1733mbps backhaul for connection between router/satellites.
    • plemans's avatar
      I do see it. And it shows up to 866mbps. As I went over earlier for the fronthaul.
      Fronthaul: the 5ghz you can connect devices to
      Backhaul: link between the router and the satellites that is dedicated just for that.
      • Chev3re525's avatar
        Chev3re525
        Tutor
        Thanks. We Crossed Comments When I Posted The Image.
        After Posting The Image I Did See Your Reply.
