Bernarusan's avatar
Bernarusan
RBR40 will no connect to Internet
My Orbi RBR40 suddenly stopped working. No internet. I checked the modem and actually had to go back to using the modem in order to have Internet, even if only in certain parts of my home. I tried reseting through disconnecting and reconnecting, and also with the phone app, but the rim remains red. It does connect to my devices, but they say Connected - no Internet. It's quite possible that it's busted, but in order to get a replacement, I noticed that now the router model is RBK40. Will this RBK40 work with my current satellites?
  • FURRYe38's avatar
    Try a power OFF of the isp modem for 1 minute then back on. Factory reset the RBR and walk thru the setup wizard with a wired PC. See if it reconnects to the modem.
    Yes you can.
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-c
    • Bernarusan's avatar
      Bernarusan
      Firmware is V2.3.5.32. Modem is Alcatel Lucent I-240-WR. The thing is that my setup is been working fine for a couple of years, until the RBR40 simply stopped receiving Internet. The modem is a very simple modem and has no router function, and the RBR40 I believe has no modem function.
      Do you know if I can use a new RBK40 with my current 3 satellites RBS20?
      • FURRYe38's avatar
        Yes you can.
