encrawford
May 04, 2021Tutor
RBR40
I have an RBR40. I recently upgraded my ISP to a gigabit service. When I connect my cable modem directly to a computer I can get download speeds of 900 Mb per second. However, as soon as I connect the Orbi router my speeds drop to around 290. I can't seem to get a straight answer out of tech support as to whether this router supports higher speeds are not. I don't mind having to upgrade to a different model but I'm still struggling to get a straight answer out of tech support as to what speed my current router supports.
Since I only have a 1 GB service (and my switch only supports speeds up to 1 GB) and I already have a cable modem it appears this model would be the best to upgrade to. Would you agree? I also have two satellites with my current configuration.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Do you have Armor, Access Control, Circle or Traffic Meter enabled on the RBR?
it is my modem and it is in Arris SB 8200
And the Orbi firmware version is V2.5.1.22
