tgarvey
Oct 11, 2018Tutor
RBR40/RBS20 dropped connections
I have an RBR40 and three RBS 20s. All are on FW 2.2.1.210. Several times a day the satellites loose connection to the RBR40. They are in "Magenta" state much of the time. I have a two-storey, 31...
tgarvey
Oct 12, 2018Tutor
Thank you for the suggestions. I manually selected chaneel 6, for 2.4, disabled MIMO and turned off 20/40Mhz Coexistence. I had turned off Daisy Chain a while back and left it that way. IPv6 was alreday off. I hard re-booted all units. No improvement. Very frustrating.
One of the satellites that I use the most and have a lot of trouble with is about 30' from the router and literally has line-of-sight through two windows. Also, frequently while I'm connected to wifi with an "Excellent" signal I get "no internet connection." My cable modem is a Netgear CMS700 connected to the RBR 40 via ethernet cable.
I have several neighboring networks, though only two of them are currently showing up on my iOS devices and my Windows PC.
I think I manually got the updates.
Any other thoughts? Try different channels?
Oct 12, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
How was the v210 FW updated, via auto update in the UI or manually installed? Was a power cycle OFF of the system and back on performed after the Update? Try this...
