BillYoung
Sep 22, 2021Luminary
RBR50 - Cannot log in to 10.0.0.1 or orbilogin.com after firmware upgrade
To whom it may concern:
I have upgraded the firmware on my router to 2.7.3.23 in order to fix the issue with Attached Devices. Upon updating the router (satellite upgrade went fine), I can no longer use orbilogin.com or 10.0.0.1 to log in to the router. I continually get ERR_CONNECTION_TIMED_OUT when trying to access either site.
192.168.1.1 is the address for my modem, and connecting to it works fine.
So, what can I do to resolve this issue?
CrimpOn:
I figured out the problem. My laptop, which is connected via WiFi, was connected to my Guest Network, not the Main Network. I reconnected to the Main Network, and it allowed me to connect to orbilogin.com.
Problem solved.
Are you wired to the router, or using WiFi?
If wireded, can you ping the router? (open a command window and type ping 10.0.0.1)
