Belovednewo
Sep 10, 2022Guide
RBR50 - No Internet connection
I’m having the same problem. Also connected to AT&T fiber modem/router. Setup has worked fine for almost 3 years until about a week ago. Modem is set to IP Passthrough and both wifi channels are turned off. It’s been driving me crazy too.
- ekhalilMasterWhat config do you see on the Orbi web GUI when you check under >> ADVANCED >> Setup >> Internet Setup.
Please follow the all the steps in the following page to have a complete passthrough setup in the BGW210: https://spin.atomicobject.com/2021/02/19/ip-passthrough-bgw210-700/- Yes all the IP Passthrough settings are the same as that article.
For Advanced > Advanced Setup, I don’t see anything called Internet Settings but I do have Wireless Settings.
Region: North America
Under 2.4GHz
SSID Broadcast is checked
20/40 MHz Coexistence is checked
Enable WMM settings is checked
CTS/RTS Threshold 2347
Preamble Mode Automatic
Transmit Power is 100%
Under 5GHz
Same settings (except 20/40 since it isn’t an option)
Daisy-chain is unchecked (I only have one satellite)
Implicit BEAMFORMING unchecked
MU-MIMO checked
Fast Roaming unchecked- ekhalilMaster
Please provide the settings under > ADVANCED > Setup > Internet Setup
