NetBoy13's avatar
NetBoy13
RBR50 - Problems setting up devices requiring 2.4GHZ and using an iPhone (Yes, I've searched)
Here's my setup:
RBR50 with 1 Satellite (running firmware 2.5.2.4)
iPhone 7 (iOS 14.2)
Device - Inkbird Grilling Thermometer (requires 2.4Ghz)
Here's what I've tried:
1) Followed mfr's instructions - Did not work
2) Turned 5Ghz down to 25% - Did not work
3) Disabled broadcast of 5Ghz on RBR50, forgot network on iPhone, re-enabled network on iPhone - Did not work. iPhone repeatedly connects via 5Ghz.
4) I started to try and telnet into the RBR50 to poke around per some other suggestions, but not successful:
telnet: connect to address <my router ip address>: Connection refused
telnet: Unable to connect to remote host
At this point, I'm at a dead end. I have no other issues with my network. There are 24 devices connected with no issues whatsoever. Thanks for any guidance you can provide.
  • plemans's avatar
    when mesh networks first came out, I used an old router or even hotspot. I'd set it with the same ssid/password as the mesh router and only have its 2.4ghz on. I'd shut off the mesh network, setup the device on the hotspot/old router, then shut off the hotspot/old router, and the IoT device would auto connect to the orbi.
    I haven't had to do that in years but its an option.
  • CrimpOn's avatar
    CrimpOn
    Both the "fast flash" and the "slow flash" failed?  At which step did they fail?
    https://inkbird.shop/collections/wilreless-thermometer/products/ibbq-4t
    How was it determined that the iPhone connected at 5G? (from the Orbi "Attached Devices" display or from wireless settings on the iPhone?)
    • NetBoy13's avatar
      NetBoy13
      Fast Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1/90, 2/90 etc.)
      Slow Flash - Fails / Times out at the step where it is trying to make the connection (screen on phone shows 1%, 2% etc.)
      I determined that the iPhone was connected via 5G from the Netgear Attached Devices screen. When I forgot the network on the iPhone, I waited until it disappeared from that screen, then I logged back in and waited until it reappeared.
      • CrimpOn's avatar
        CrimpOn
        Thanks.  It's frustrating that the iPhone network setting does not show the connection frequency? (My Android clearly says "Frequency 5G" or "Frequency 2.4G". )
        The video is so blurry that I cannot figure out the difference between the WiFi states that the user chooses from. Have you tried them all?
