drfrink24
Feb 28, 2020Aspirant
RBR50 and RBS50 Ethernet stopped working
1 RBRv2 and 1RBSv2, been working fine for several months
Around 9pm CST last night, all my connected ethernet devices quit functioning, wireless devices are working fine;
Actions taken, with no results;
1. Swapped switch, thinking it was bad, no improvement
2. Tested backhaul cable using Cat5 testing equipment - tested fine
3. Rebooted RBR/RBS, no improvement
4. Tried direct wired connection to RBR with Ubuntu server - Link status shows 1000/Full in Orbi with fixed IP address, cannot ping/connect to the Orbi admin webpage
5. Wired via switch - DHCP assignment fails, static IP address (same subnet) fails to connect to the admin webpage by IP address
6. Updated both RBR and RBS to latest firmware v2.5.1.8 - no improvement
7. Swapped RBR/RBS locations, trying the ethernet ports on the RBS - same symptoms/no improvement (this also tests leaving them unplugged for 1 minute)
8. RBS won't connect via direct wired backhaul (this was working for months)
9. Disabled Daisy Chaining (saw it in another thread) no improvement
10. Changed the IP address and subnet on the router - no improvement
11. Disabled/enabled the DHCP server on the RBR - no improvement
I'm perplexed as to how both the RBR and RBS seemingly lose ethernet functionality. They are physically connected, link 1000/Full for all clients.. just not functional. It's as if the RBR has quit routing all ethernet traffic (including the RBS Backhaul) except the WAN ethernet.. (I'm typing this from a wifi connected device, and it's working fine).
Tried two switches in the configuration, identical problems for both, so it was something on either both or one of the PCs. Problem went away when I booted them to their OS.
What is the Mfr and model# of the ethernet switch in the configuration?
Is the Orbi system operating in Router or AP mode?
I would reset both RBR and RBS. Directly connect the RBS to the back of the RBR and walk thru the RBRs setup wizard with a wired PC and web browser.
- drfrink24Aspirant
I've tried two switches - One of them is a 24 port netgear unmanaged 1gb switch, the other was a 5 port tplink 1gb switch. Wired backhaul eliminates the switch(s) from the equation, wired backhaul doesn't activate/enable. Direct wired to both RBR fails to assign DHCP addresses and elminates the switches from the equation. Direct wired to Sattelite fails to assign IP addresses and eliminates the switches from the equation.
No factory reset, as that would be my last ditch, nuclear option.
Router mode - I don't want to use the ISP DHCP settings for AP Mode.
Wireless clients get IP addresses, updates are reflected. Wired does not serve IP addresses. Static address fail to ping gateway (yes, they are on the same subnet)
I will reset everything tonite, as obviously the Orbi system is a black-box that has no tracing/logging/debug capabilities.
reset > hard reset > factory reset > replace unit
I should have spend a few hundred more dollars for a real mesh system from Ubiquiti
Try this, factory reset the RBS and connect 1 wired PC to the back of the RBS. Don't sync it to the RBR. Just wait about 5 minutes. Open a web browser to 192.168.1.250 and this should present you with a log in page. Use admin and password. Can you get to the RBS default web page here? If so, Then try to resync with the RBR. Do this with the RBS in the same room with the RBR.
If a factory reset on the RBR and RBS fail to get the RBS re-connected, then possible the RBS maybe faulty.
