MOmair's avatar
MOmair
RBR50 Constant Reboot (every 30 seconds)
Hi,
I have been using Orbi (RBR50 + 1 x RBS50) since last 3 years. I had no issues whatsoever. Since last week, RBR50 has been restarting every 30 seconds. I have tried updating to the latest firmware, tried flashing Voxel firmware (but couldn't boot), downgraded the firmware but the problem persists. I have disconnected the modem from the router but still constantly reboots. I am not able to access the orbi login without router constantly rebooting.
I have changed the socket, changed the adapter, removed the modem so that I can check if its a double NAT or any other modem related other but nothing has worked so far.
i am at my wits end here. I have gone through a lot of solutions given in the form and flashed to latest fw release and have tried down to 2.6.1.40.
i need to fix the router as i do not have any budget for a new router.
Thanks in advance.
  • plemans's avatar
    Try swapping one of the power supplies from the satellite with the router.
    Maybe the power supply is going bad
    • MOmair's avatar
      MOmair
      Thankyou for taking the time out to reply. I have tried using 2 other power supplies. One from satellite and one borrowed from another friend. Result is the same.
      Is there a way I can find out what's causing the reboot. I am at the brink of going crazy over this failure of a hardware, working my job during the day and trying to unbrick this during the nights.
      So far I have tried:
      - Using Orbi in AP mode.
      - No ISP router connected
      - No Satellites connected
      - Flashing Voxel firmware but I wasn't able to boot and access orbilogin.net
      - Flashed back to latest version
      - Hard reset (30 seconds) after fw update
      - Soft reset (blinking power light) after fw updates
      - Power off, unplug every thing, then turn on after 30 mins
      Currently using stock fw v 2.6.1.40. Boots fine, solid magenta light, WIFI dropping again and again.
      • CrimpOn's avatar
        CrimpOn
        Something appears to be inconsistent.  If the router reboots every 30 seconds, that does not allow enough time to do much of anything, such as
        • Manually install a different firmware version?
        • Change from router to AP mode?
        To me, there is a difference between the router actually rebooting and the WiFi signal disappearing.
        Would like to help, but am confused about the problem statement.  Sorry.
