Weberdee
Nov 09, 2019Aspirant
RBR50 diconnecting from internet
Hi
I have an Orbi RBR50 connected to a satelite RBS50 linked via the RBR50 to a BT modem.
Sometimes our internet connection stops and this is now happening more frequently, Its now been 2 days in a row.
When this happens we cannot access the rest of our network. Hence I believe it to be related to the RBR50.
If I disconnect power to the RBR50, wait and power up again, then the internet connection is re-established.
Any suggestions welcome.
- pmcgee3AspirantTry using a cat 5 6 or 7 cable. The same thing happened to me so I changed out the cables and use the CAT5, no problems ever since. Good luck!
- WeberdeeAspirant
Thanks, we have cat 6 throughout the house.
Its been working fine for a couple of years.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopHas a factory reset and setup from scratch been performed since last FW update?
Weberdee wrote:Hi
Weberdee wrote:
Hi
There's the problem. As FURRYe38 suggests, you are in "Double NAT" territory with two routers on your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR SupportThe horrid BT Homehub blocks any "modem only" settings. The easiest option is to put the second router, your Orbi, into AP mode.
That has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportBut for most people this does not matter.
- WeberdeeAspirant
Thanks everyone,
As suggested I've had to use the BT hub as the router and the Orbi as an AP. Turning off the BT hub wireless and using the Orbi wireless.
I tried the suggestion of accessing the BT hub option to set it in modem mode but as said above this did not work.
Its worked fine now for a few days.
There are alternative options. They are a bit complicated, and may also be beyond the capabilities of the execrable Homehub, but if you want to get wifi from the BT's box of tricks, you might like to investigate.
- Retired_Member
did you ever answer the question about the firmware?
