pkengr
Feb 19, 2017Tutor
RBR50, Draining mobile phone and tablet battery
Issue: Have new Orbi router and satellite. Install was vanilla - no issues. Updated firmware on both components to latest (a week ago). Worked as advertised- great, as a matter of fact. However, i...
loomis1975
Feb 20, 2017Luminary
I forgot to mention that also during this time period, I also lowered the transmit power on the Orbi system for the 2.4 Ghz band down to 25 percent. This also might have helped with the problem at my place where the Orbi is installed.
MyNGpro
Feb 20, 2017Tutor
Hi,
This is definitely not the problem of the S7 as I also have LG and ZTE cell phones that act the same,
Battery drain that caused by the NETGEAR Orbi equipment .
So it is easy to put the blame on others...not this time.
Something is causing the problem on the Orbi side of the scale.
Please solve the problem A.S.A.P as it is definitely a software glitch.
Thx.
