spqr105's avatar
spqr105
Tutor
Mar 24, 2021
RBR50 dropping some 5Ghz internet connections
Hey guys,
So over the past 2 weeks certain 5ghz devices such as my smartphones, ring doorbell and devices hardwired to 1 RBK50 satellite (we have 2) have randomly been dropping their internet connection but maintaining their connection to wifi.
I have tried disabling beanforming, mu-mimo, 20/40 coexistence and experimented with every 5ghz channel. All of these worked fine for 2 years prior to the past 2 weeks. I already had wmm enabled and fast roaming disabled. All 2.4ghz devices are working fine.
I also experimented switching from my ISP's DNS to Google's DNS.
Does anyone have any clue as to what could be causing this and how to fix it? I will reset the router and everything will work fine for about 12-24 hours and then they start dropping again.
Thanks in advance for your help!
  • FURRYe38's avatar
    Is the Orbi syste
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    • spqr105's avatar
      spqr105
      Tutor
      Firmware ends in 104 for router and satellites.
      ARRIS SURFboard SB6190 DOCSIS 3.0 Cable Modem and is working fine.
      Home is 4500sqft and there is about 50ft between the router and satellites.
      My nearest neighbor is 300ft from my house. I have experimented with all of those configurations you mentioned.
      • FURRYe38's avatar
        Might bring in the RBS to say 40-45feet and see.
        Try some of the suggestions. IF a reset hasn't been done, I would try this first off.
        Also besure that Traffic Meter is disabled.
