RDMSYS's avatar
RDMSYS
Star
Jun 05, 2020
RBR50 Firmware Update
I have a notification for new firmware (V2.5.1.16). However when I do the check, the router firmware is found but my Satellite stays at Please Wait A minute for 5 minutes then fails. I would like to apply it but I'm not sure with this issue.
Anyone else see this?
  • It usually should do everything, however maybe some times that doesn't work. So the alternative method of manually loading FW is available. Glad it worked for you. Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
    • RDMSYS's avatar
      RDMSYS
      Star
      Thanks but I would rather let it do it. I was thinking of doing it via the app. I'm still not sure that it would have issues or not.
      • plemans's avatar
        "let it do it" doesn't seem to be working. You can leave it as is but I wouldn't recommend updating via the app, especially if you're already having issues. Reason why is it tends to be the devices that were updated via the app or wireless that we tend to see corrupt firmware issues on.
        But again, up to you.
    Just did from iPhone and worked correctly.
