JTrtt's avatar
JTrtt
Tutor
Oct 08, 2018
RBR50 heavy battery drain on iPhone SE
Purchased RBR50 on 08 October 2018. Firmware V2.2.1.210
One Orbi Satellite-1
Six connected devices: Two iPhones running OS/12, a Windows 10 Desktop, a printer, a Roku, a sterio receiver TX-8170
MU-MIMO is disabled
Beamforming is disabled
Fast Roaming is disabled
Daisy Chain is enabled
The battery on my iPhones (an SE and a 7) drain visibly while I watch. In a matter of hours, it went from 60% to 10% battery.
Did not have this problem with the older wireless router.
I have two weeks to solve this before returning the device to BestBuy to get a competitor product.
 I would appreciate any help.
  • Good to hear. Mark this thread as solved so others will know when needed.
    Enjoy. :smileywink:
    JTrtt wrote:
    I promised to update after a few days of testing. After doing the following, the battery drain on my iPhone SE has improved so that it is only consuming 10%-20% per day which is very much better than I had before. I am encouraged. Thank you FURRYe38 and pdang for the help!
    Here is what I did:
    On the Orbi RBR50
    • Enabled MU-MIMO
    • Enabled Beamforming
    • Enabled Fast Roaming
    • Enabled Daisy Chain
    On the iPhone SE
    • Disabled Screen Time (a huge improvement; see https://www.idownloadblog.com/2018/10/08/ios-12-screen-time-iphone-battery-drain/)
    • Turned off Background refresh on apps I don't need
    • Started using Airplane Mode + WiFi while at home. An article suggested this would save both because both radios are not on and it is not constantly checking for cell coverage. I don't know if that is true but it seems to have helped.
  • FURRYe38's avatar
    I would enable Beamforming as that can be enabled. I don't think the SE phone is MIMO capable. The 7 might be so you could try enabling MIMO and see. Disable it if you don't see any differences.
    Can try this:
    Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
    https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
    "I changed the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only."
  • FURRYe38's avatar
    Any status on this?
    MU-MIMO is disabled
    • JTrtt's avatar
      JTrtt
      Tutor
      Thank you for the advice so far. I have done the following:
      • Enabled Beamforming and MIMO
      • Disabled Screentime on my iPhones (by default, it was enabled on my phone and disabled on my wife's)
      • Reduced power on the 2.4 GHz channel to 25% (only used by my printer)
      I am also looking at using Airplane Mode (with wireless on).
      I reckon I need to test this for a day or two to see if this resolved the issue.
      I will update this note by end of the week.
  • I promised to update after a few days of testing. After doing the following, the battery drain on my iPhone SE has improved so that it is only consuming 10%-20% per day which is very much better than I had before. I am encouraged. Thank you FURRYe38 and pdang for the help!
    Here is what I did:
    On the Orbi RBR50
    • Enabled MU-MIMO
    On the iPhone SE
    • FURRYe38's avatar
      Enjoy. :smileywink:
      Here is what I did:
      On the Orbi RBR50
      • Enabled MU-MIMO
      On the iPhone SE
