avicar's avatar
avicar
RBR50 keep disconnecting at random times
Hi Community,
After a lot of searching I bought an Orbi RBR50 with 2 Satelights. Was easy to set up and internet speed was great.
After a day or two it started disconnecting from the internet at least 3 or 4 times a day.... This is really really annoying and doesn't match a high end mesh like Orbi and the price it costs.
I'm minutes away from returning it.
Data -
  1. Every time there is no internet at the house, disconnecting the cable to the wall (internal from ISP is directly from the wall, no router or log-in needed) and connecting back solves the problem
  2. Reading around the community there was an advise to change the lease timer, i changed it to 750 through telnet. Nothing changed.
  3. I contacted Orbi support and they made me downgrade Firmware to 2.3.5.20. Nothing changed. I still get disconnects at least 3 times a day
At this point I'm out of solution. This is really disapointing for a procut like this and I'd appreciate help
thank you
  • CrimpOn's avatar
    CrimpOn
    It would help to know exactly what the internet service is.  "Internet cable to the wall" sounds like "not a typical cable TV distribution".
    Is there perhaps a typo in the firmware that Netgear recommended?  i.e. 2.3.5.30 rather than "20"?
    • avicar's avatar
      avicar
      Hi there, thank you for trying to help out !!
      Yes about the typo - It is V2.3.5.30 indeed
      About the internet, I'm connected through Frontier in the US. Sorry for not knowing the actual profession terms. What I meant is that the connection doesn't require any user/PW. You can plug-in your cable directly to the wall and you have internet and this is where Orbi is connected and how it was configured.
      I just another disconnect and looked at the logs if that helps.
      [UPnP set event: add_nat_rule] from source 192.168.1.10, Friday, April 17, 2020 22:42:55
      [UPnP set event: del_nat_rule] from source 192.168.1.10, Friday, April 17, 2020 22:42:30
      --------- at this point there was no internet and I went and disconnected the cable and connected it back
      [UPnP set event: add_nat_rule] from source 192.168.1.10, Friday, April 17, 2020 22:41:26
      [admin login] from source 192.168.1.10, Friday, April 17, 2020 22:41:13
      [UPnP set event: del_nat_rule] from source 192.168.1.10, Friday, April 17, 2020 22:41:08
      [UPnP set event: add_nat_rule] from source 192.168.1.10, Friday, April 17, 2020 22:40:05
      • CrimpOn's avatar
        CrimpOn
        Probably a good idea to determine which device in your network has IP address 192.168.1.10
        When I Google for "UPnP set event: del_nat_rule" I find lots of results about Windows Media Player.
        There is a setting in the Orbi web interface, Advanced Tab, Advanced Settings, UPnP where you can turn UPnP on or off.
        Do you have devices or services that require UPnP?
  • FURRYe38's avatar
    NG isn't advising users to revert FW when new FW has been made available:
    https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
    avicar wrote:
    Hi Community,
    Data -
    thank you
    • Anonymous's avatar
      Anonymous
      The fact that even NG support is advising users to revert to  2.3.5.30 should be proof alone for the disbelievers who hold on to their dozens of useless questions
