RJSinMO's avatar
RJSinMO
Guide
Dec 19, 2023
RBR50 pulse white, then flash green and red and reboots endless
I have an RBR50 that about a week ago hung up.  I powered off and on and now it just pulses white and then will do a quick flash of green and flash of red (on top ring).  I factory reset it, and even applied latest firmware, and it came up briefly.  But, it seems every time I change the SSID to my network and thus all the devices try to jump on, it goes right back to endless rebooting loop.  I do see the SSID pop-up momentarily on my devices, and a computer with network cable gets a signal briefly also, just before it starts the next reboot.
The RBR50 is from 2018, so well out of warranty, so I assume Netgear won't help.  Any thoughts, or is this thing just dead?
  • I've confirmed a few things.  If I factory reset it, and it comes up with the ORBI02 SSID, it is fine, and I can connect to it from my laptop.  If I change it to something else, it is fine.  But as soon as I change it to the SSIS that it has been for 5 years and all of my devices connect to, then the RBR50 crashes as soon as it comes up and goes into a booting loop.  Most recent devices I can think I added are some cameras, so I'll try turning most devices off and adding them one at a time.  However, when Orbi is down, I'm changing my T-Mobile router to that SSID and all the devices connect to it just fine.  So, even if it is a particular device, this should NOT be crashing ORBI.
  • Well, it seems like one of the satellite's was hanging it up.  Once I turned off that satellite, the main router fired right up.
    • FURRYe38's avatar
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      How many RBS are deployed?
      What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
      https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
