hollang's avatar
hollang
Tutor
Jan 13, 2019
RBR50 ReadySHARE USB Printer
I have Orbi RBR50 with two satellites. From a wifi perspective it works great, but for the life of me I can't get a HP CP3252 Color Laser Jet printer to work over the USB port on the back of the satellite in my office.  The printer works fine if I put it's USB cable directlyl into my PC, but nothing happens when I put the cable into the Orbi's USB port.  I've downloaded and installed the ReadyShare print software, but it isn't working as described.  The installation goes without complaint, but when I select English Language on the initial screen and hit OK, it just goes away. I don't ever see any further screens and certainly not with anything that looks like a list of printers which the (limited & mostly inadequate) documentation seems to suggest should happen.  I'm running a new HP Omen Windows 10 64 bit PC. Any suggestions welcome
  • Thanks again. In the interim, I uninstalled the driver and the ReadyShare software and reinstalled them and now it's working correctly. Guess some kind of conflict occurred. So, I thik I'll just stick with the USB connection as I don't use this color LJ very often.
    • hollang's avatar
      hollang
      Tutor
      Thanks. I’d reviewed that information, downloaded & installed the app with no complaints but it’s not operating as described. I get the language prompt screen but nothing follows it. I would use an Ethernet port but I need them all. Maybe I can connect up an energy switch to get more ports. …? Thanks, though for your inputs.
      • FURRYe38's avatar
        Possible something wrong with the app. Maybe a forum moderator can help.
        Blanca_O
        Yes you can add a external Gb network switch to the back fo the Orbi router for more ports. I have a 24port and several smaller switches behind my router. Non managed, non smart and non green eithernet is preferred. NG GS308 or D-Link DGS 108/105 or HP 1400 series works great.
