mgdurand1
May 13, 2019Luminary
RBR50 replacement
I have used my Orbi system with very few problems for 2 years and 6 months. Had a 2 year warranty so of course the dropouts started soon after the warrarnty died. I used multiple RBS50 satellites and so I wanted to see what newer unit would pair with them. The Pro does not apparently. So I started looking for a new RBR50 to replace my existing one. Can't find one. I do find the RBK50. So, my quesiton is, if I do decide that the current dropouts cannot be dealt with (and a l ot of people are seeming to have that happen) and I opt to try the hardware route, will a new RBK50 pair with my RBS50 satellites? Thanks.
Lets see if it's actually a hardware or configuration issue first.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since updating to v60?
