Sarabpaints's avatar
Sarabpaints
Follower
Sep 26, 2022
Rbr50 reset Orbi and now it won’t connect to the Internet
I have an Orbi90 rbr50 and it won’t connect to the Internet. Every time I restarted it it would go back to the pink light. So I reset it and now it is a white light but it is still not working. How do I Connect it so it works? I need it desperately
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Jeezy's avatar
      Jeezy
      Tutor
      OP did you manage to sort this? I am having the same issues.. wirelessly I am getting slow speeds. I tell you what Netgear Orbi is a pain in the ass. I regret getting this. You would expect for such a expensive equipment you wouldn’t have much headache with it
      • FURRYe38's avatar
        The user hasn't been back since they posted nor responded to my suggestions.
