alexpollard's avatar
alexpollard
RBR50 Satellite keeps dropping connections
Connection has been rock solid since I bought it but recently my satellite connections keep dropping. I know because I lose connectivity to my NAS connected over ethernet. Rebooting the satellite eventually resolves the issue. I can't ping the address of the sattelite when this happens so know it's not related to the ethernet connection or my NAS. I've downgraded the firmware as I read that this might be the issue but it didn't resolve so I've put it back on the latest version. Only seems to happen every few weeks or so.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Has a factory reset and setup from scratch been performed since last update?
    • alexpollard's avatar
      alexpollard
      Firmware is V2.5.1.32
      Virgin Media UK in Modem Mode
      Tried messing with a few settings - wireless has been rock solid as I say for around a year since I bought it, it's only recently that it has started playing up. I get full speed pretty much everywhere in my house.
      Yes but I restored my settings as I have many port forwards etc for the NAS and it would be a right pain to set this all up again.
      • FURRYe38's avatar
        You might downgrade to v16 on the RBR and RBS. v32 saw some problems. NG pulled this version from there servers.
        Factory rest the RBR and RBS and setup form scratch. Don't apply the backup config from file initially. See if the RBS fails again. If not, then try loading the backup config from file.
