Johnhorton1979's avatar
Oct 31, 2022
RBR50 Solid Purple/Magenta light after power cut
Hi all
I have an issue with my RBR50 after a powercut i now cannot get it working there is a solid purple light, I have run through all the trouble shooting for resetiing but the reset doesnt seem to work. there is also astarnge issue now where NETGEAR75 is shown on my wireless network list too.
I have tried the 3 different reset options
i just cannot get it to work
Anyone offer any advice please?
Regards
John
  • FURRYe38's avatar
    So if you disconnect the RBR from the modem and press the reset button for 15 seconds then release and with 1 wired PC connected to the RBR, after the top ring LED slowly pulsates WHITE, can you access the RBRs web page at 192.168.1.1 at all?
