EricToo's avatar
EricToo
RBR50 Update to Firmware Version 2.7.2.104
I attempted to upgrade to Firmware Version 2.7.2.104
The update attempt failed and I could no longer access the router by logging in on my computer.  This occured shortly after the firmware was released, October of 2020 as I remember..  The Netgear tech support team could not fix the issue.
Yesterday I logged into the router from my cellphone app.  A button appeared.  Clicking on it upgraded the firmware to v2.7.2.104. on the router and two satellites.
WOW!
So today I tried to logon from my computer again to see what would happen.  Same problem as before.  I can completed the logon sequence, but could not access the web pages showing router and satellite status (or anything else for that matter).  So I went back to the cellphone and all seemed to be ok.
Currently, the orbi system is functioning normally (just as it was before the upgrade).
Does this behaviot suggest a known orbi RBR50 problem?  Has anyone seen this sort of thing before.  Does it suggest some sort of hardware problem?  So sort of persistent firmware problem?  Something else?  Ca this issue be fixed?  Any suggestions at all about what else, if anythiing, can be done?
  • from your post I can't make out if you have a problem or not.
    with regard to 2.7.2.104, I would do a search in the forum.  Lots of folks having problems as well as using the app.  Many have dumped the app.  I never use it.
  • FURRYe38's avatar
    Power OFF the RBR for 30 seconds then back ON.
    Be sure to clear out all browser caches.
    Use IE11, Edge or Firefox to access the RBRs web page at 192.168.1.1 or orbilogin.com
    Last resort is to do a factory reset on the RBR and walk thru the setup wizard with a web browser.
    Avoid using the Orbi app for any FW updates.
    WOW!
    • EricToo's avatar
      EricToo
      Remember.  The Netgear tech support team with escalation could NOT fix the issue.  I coonsider this to be a significant matter because  Netgear advises that no firmware updates be performed using the Netgear app.
      • vajim's avatar
        vajim
        Master
        If only more people here understood that this would be a happier place to exchange ideas and experiences.
  • i almost forgot, standby for 1000 questions from those who believe all is well with the firmware such as 2.7.2.104
    nice way to spend your day....enjoy
