cblaze22
Mar 06, 2021Tutor
RBR50 V2.7.2.104 Firmware update now is dropping signal randomly
I had a working mesh system with my RBR50 and 1 satellite for almost two years. I just updated to V2.7.2.104 and now drop signals all over the place. I even reverted back to older firmwares and still same issue. Did I corrupt my router somehow? I of course have done many factory resets trying to fix this.
- vajimMaster
cblaze22 wrote:I had a working mesh system with my RBR50 and 1 satellite for almost two years. I just updated to V2.7.2.104 and now drop signals all over the place. I even reverted back to older firmwares and still same issue. Did I corrupt my router somehow? I of course have done many factory resets trying to fix this.
wow...and you reverted back and the problem is still there?
yes there are lots of reported problems with V2.7.2.104 and many have been able to revert back.
you may want to keep trying to roll back/factory reset.....
tip: no more manual firmware updates....too risky
- cblaze22Tutor
I may of figured out the issue. I decided with my original setup to split the 2.4 and 5 into their own channels via telnet. I kept doing this after the firmware update.
This time I decided to keep it on one band and I havent had any drops yet. If I see any drops Ill let this thread know but until then it looks like the newer firmware are having issues with split channel names.
I reverted back to an older firmware, however I didnt know the exact firmware. I went to 2.5 and was the same issue so I probably had a firmware originally that did not cause issues with the dual channel names.
- vajimMaster
Wow
lots of changes and tweaks
good luck
