hartcb's avatar
hartcb
Tutor
Dec 28, 2020
RBR50 with 1 RBS50s - Wifi Calling Drops Constantly - on latest firmware V2.7.2.102
Hi All,
I've been working on this issue for 2+ months and have made all the rounds - to Apple, to Verizon, and read through all the forums here for similar issues.
It seems no matter what I try, I get get wifi calling to stop dropping on my network. It worked for 2 years and then started dropping about 2.5 months ago. I've updated my firmware to the latest on all three devices: firmware V2.7.2.102, I've replaced the iPhones (now two 12 Pros, and an 11).
The symptom is a wifi call will start for 2-5 minutes and then fails every single time. It doesn't matter if I have cell service turned off (airplane mode) and am on wifi only or not.
If anyone can help I would really appreciate it!
  • hartcb's avatar
    hartcb
    Dec 31, 2020
    UPDATE - xfinity modem replaced, connectors on my line snipped and reconnected, and wifi calling seems to be working. 20 minute call is just completed and still running. I believe that was ultimately the issue.
    So, after investigating with Netgear equipment, Apple phones, my network, various settings, etc... it came down to the cable / internet provider. I don't know that I'll ever know what caused it, but happy it appears to be fixed! Hopefully, this helps someone else.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • hartcb's avatar
      hartcb
      Tutor
      Thanks for the response - please see below:
      • The ISP Modem is a xfinity XB6-A
      • Home size is 2,000 square ft. plus or minus (with 1 router and 2 satellites I have very strong signal throughout the house)
      • Distance router to satellite is 15 ft. (but going through a couple of walls) on one and 25 ft. (going through a door) for the other. This has been the configuration for 2 years or so with no issues until the last 2.5 months.
      • 2.4Ghz was Auto, changed setting to manual channel 1
      • Wifi Neighbors - just one shows up and only 2 bars (ATT)
      • Beamforming and MIMO were already enabled from prior post suggestions - left those on
      • Factory reset and setup - done just before I updated to the latest firmware today.
      • Per the other post you included a link to I have now given both satellites static IP addresses as well.
      • All other configurations are as you suggested.
      RESULT: wifi calling is still dropping after 2-3 minutes on average, this continues to happen if I am on wifi only (airplane mode with VZW Wi-Fi on the iPhone), or have the cellular on (my at home cell service is terrible, hence the need for wifi calling - definitely is harming my work at this point...)
