Viberoom's avatar
Viberoom
RBR50 working fine for 14 months - hard reset now can not connect to modem
Hi. I have been using my Orbi with 4 satellites around my house just fine for more than a year. Yesterday I tried to do a hard reset of the router for the purpose of splitting 2.4 and 5ghz. However when setting up Orbi as new again I can not connect to modem.
A couple of points...
Modem is a product by telecom provider.
I have had their technical support to my house and they have set up a new router with one of their own products (not Orbi) and is working fine.
I have a second Orbi router brand new (RBR20) which I also tried to set up in case a problem With my RBR50 tho that would not connect to internet either.
Modem is working just fine. And now supplier router is working just fine too. Tho my Orbi is not connecting.
I have tried everything online
  • FURRYe38's avatar
    What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router with the modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • Viberoom's avatar
      Viberoom
      Thanks for the reply.
      Please note that the internet provider modem is modem only. I have taken a photo of the modem model attached to this thread.
      I understand the additional methods you have proposed and I have followed them online prior to now. Problem I have with those is that even connecting to either the RBR50 or RBR20 (brand new), I am unable to set either of them up. I then connect direct to to the Orbi via lan to one of my computers and still can not set up.
      • Mstrbig's avatar
        Mstrbig
        Master
        I'll assume you rebooted the ISP modem before you attempted the install?
        Also I find sometimes the Orbi routers don't fully reset.
        I would reset again, watching the power light go through its colors and make sure reset is successful. Then install again.
